How often should I change the oil?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by HMCK20,Oct 1 2006, 07:55 PM
haha its hot in FL. there is alot of retarded traffic. so yea i guess its a waste. but i wouldnt expect someone like you to understand why i do it.
"Someone like you" sounds prejudicial, and I'm sure that you didn't mean to sound that way, right?
Banned
![](https://www.s2ki.com/forums/images/s2ki/ranks/banned.png)
a total waste of money and a waste of our resources.
I suggest you pull your head out of your ass and do some reasearch....the simplest
thing you can do is RTFM.....but i wouldnt expect someone like you to understand.
![rollinglaugh.gif](https://www.s2ki.com/forums/images/smilies/rollinglaugh.gif)
lol im stoppin here. you do what u feel is needed and ill "waste" resources. cause they dont do a million other things with used oil. oh and the money part i got money to spend so ill spend it as i please.
kinda high jacking this post.. but i too havea 06 s2k but at 15% i change my oil but in my owners manuel. it doesnt say anything bout whne i should change anything else.. anyone know what mileage to change diff and other stuff like that??
Originally Posted by JackS,Oct 2 2006, 01:24 AM
When you press the trip minder the maintance minder appears with a number 1 through 6. Transmission change is due when "3" appears and Diff when "6" appears.
![wink.gif](https://www.s2ki.com/forums/images/smilies/wink.gif)
Do the numbers count "down"? Generally, the diff fluid would be changed before the tranny fluid.
As for the OPs comment:
[QUOTE]If you would read the entire post I clearly stated that I heard that the maintnence minder system wasn't very reliable.
The numbers 1 through 6 along with the symbols AorB are displayed to the left side of the MM window. No milage that I can find are related to these numbers or symbols. The only milage suggested is the differential under heavy mountainous use has a suggested change at 15,000miles.
It's in the OM.
It's in the OM.
