How Much Will The Speedom. Be Off With 4.44's?
#22
Odometer measures distance traveled. Speedometer measures speed. Another way to confirm calibraton is to use a watch on the highway. Highways have accurately spaced mile markers. At 60 MPH, going one mile takes 60 seconds. 8.25 versu 8.27%? 0.02% off is nothing to worry about, few cars have truly accurate speedos. Most read a few percent higher than true speed. And when your tires wear, the accuracy changes since the tire diameter changes. Different tires and/or air pressures change the rolling radius too.
Stan
Stan
#24
The speed sensor gives the ECU the signal from the output shaft of the tranny. The ECU then tells the speedo what to say AND it calculates what the ODO should record based on that signal. The Yellow Box intercepts the signal before it reaches the ECU so the "corrected" signal will affect both the speedo and the ODO by the same amount.
umvue
07-10-2001 09:56 AM
