How Much Will The Speedom. Be Off With 4.44's?
Originally posted by xviper
Actually, on my Yellow Box, it can be adjusted up to +/- 31.75%
I think he meant precision. You can get to 8.25% and the gear is off by 8.27%, thus you still have an error of 0.02% (insignificant actually).
Originally posted by TopSecReT_S2000
so with the J's diff we lose topspeed?
Originally posted by S2000_Europe
The revs are the same either stock and with J's 4:44 final ratio?
ps. I hope you guys are filing this info away because if you do not understand what final drive gears do and how they work, you should NOT be considering them for your car. DON'T do this mod just because everybody else is doing it.
Xviper,
I understand that the engine revs will be different, probably I did not explain myself correctly,
I am referring to the Odometer, I do not know where the sensor that measures the revs of the car is situated
Hi XVIPER hope all is well.
What I meant with the 8.25% on the yellow box is that it can
only get that close and not to exactly 8.27%. If you add up all the switches on the box you will get 31.75%.
Got my gears from Rick's (great sevice) but my local shop wants $550 for the install!
Now Is me who have dyslexia
Once I got installed the 4:44 (next thursday, not tomorrow) the odometer will show a 8.25% more speed that it is in reality.
For example; if the odometer shows 100 mph, the real speed would be 91.5 mph, is this ok? or it is viceversa
or let make it easy does anyone know which is thew binary code in the yellow box using the 4:44
I think is this 1010 0001
