how much washer fluid to fill?
Originally posted by 50cent
Is there an indicator on the stick that tells me how much washer fluid i can add?
This is the most important fluids of all in your S. You have to contact your local Honda dealership for optimum level depending on your regional temperature. If it's too low, you may run out when the outside temperature is too high or your windshield is too dirty.
Last I pulled it, the plastic "dipstick" has holes at the bottom. Just fill it until fluid covers the holes when you remove it. As others noted, overfill is meaningless (except it'll get a bit messy. )
