how much top speed do u lose
Old 11-23-2004, 01:18 AM
debos2k03's Avatar
Default how much top speed do u lose
Im asking if anyone knows how much top speed do u lose when you change ur final gear to a 4.57 or a 4.77. I want to help out my off the line start as much as possible with out killing alot of my high speed. I dont want to do a 4.77 and top speed only be 100mph. My S just blew the diff. and looking to change the gear while im in there. I have a sc and is putting 340hp to wheels. This info would be greatly aprecated.
Old 11-23-2004, 06:39 AM
menfou's Avatar
Please use "search"
Stock is 4.1 = 160mph
4.57 = 143mph(-14%)
4.77 = 137mph(-10%)
Old 11-23-2004, 08:33 AM
S2000RAT's Avatar
No, I have a 4.57 final gear and I have run 150 MPH. It runs 144 at 7700RPMS. And I have a Comptech SC.
RAT
Old 11-23-2004, 12:50 PM
Administrator
Ludedude's Avatar
http://reverendsgarage.net/index.php?conte..._calculator.php
Old 11-23-2004, 01:25 PM
9kFever's Avatar
RAT
did you do the yellow box calibration? Sure your speedo is not right.....its probably possibel to do more than said. Many members have done well over 160.
Old 11-23-2004, 01:31 PM
DaveOnLI's Avatar
How much time have you spent over 140mph?
Even at 4.77 you will still have the gearing to get 140.
Old 11-23-2004, 01:38 PM
wake88's Avatar
In all likelihood, above 145 or so is really not going to happen often unless you're some kind of maniac. I wouldn't worry about anything more than that.
Old 11-24-2004, 04:42 AM
menfou's Avatar
RAT
171mph is my maximum on stock S2000, but speedometer is not true
Old 11-24-2004, 06:06 AM
S2000RAT's Avatar
Yes I have the yellow box. And it is set as close as it can be to right on.
RAT
Old 11-24-2004, 08:47 AM
faukengenius's Avatar
I agree with the guys that mentioned "how many times are you gonna go past 140?" Personally I've only tapped into 150 a couple times but will probably not do that anymore. True some may believe i'm a maniac but that's alright. To each their own.
I'm going to be putting the 4.57 gears into my car because I feel it needs it down low and chances are i'm mostly going to be taking the car up to 80-90mps max. Because seriously who really drives their car past 130mph on a regular basis?
Quick Reply: how much top speed do u lose
