How much HP does the A/C drain?
Old 06-21-2012, 06:54 PM
  #21
AP1_Silverstone's Avatar
Originally Posted by bdo
Originally Posted by AP1_Silverstone' timestamp='1340203072' post='21796934
This is why in a near future I wanna have an electric motor running my belt so the engine don't lose any power..
I don't believe that will work, sadly. Let's assume it takes the aforementioned 5HP to turn the compressor. Google says 5HP is 3728 watts, or 310 amps at 12 volts! And that's not even accounting for startup amps...
Plus, like starchland said, there's no free power. Even if you could do it with an electric motor, it would just transfer the load to your alternator.
Anything is posible, and if I need an extra alternator, well, so be it, free power is posible, u just need to put ur mind to it...
Old 06-21-2012, 07:00 PM
  #22
fernando.'s Avatar
Two alternators running simultaneously will be the same if not worse as having your a/c compressor driven...
Old 06-22-2012, 03:57 AM
  #23
starchland's Avatar
Originally Posted by bdo' timestamp='1340328858' post='21801834
[quote name='AP1_Silverstone' timestamp='1340203072' post='21796934']
[/quote]
1 hp=746 watts
When you find the secret to "free power" you will be a rich rich man
Old 06-22-2012, 06:46 PM
  #24
I let u know
Old 06-22-2012, 07:23 PM
  #25
GSteg's Avatar
Free power. lol...
Old 06-22-2012, 07:40 PM
  #26
Curtis61's Avatar
Originally Posted by Curtis61' timestamp='1340105492' post='21793281
I'm pretty sure the compressor stays on at WOT. My Mazda 3 even cut it off at WOT, why the s2k doesn't idk.
I think we have a high RPM cutoff, like 7K or thereabouts, but no WOT cutoff. I don't have a source to cite though.
That's probably accurate. Today I went WOT and the compressor didn't kick off, so it must be as your saying. Guess I'll stick to turning that AC button off when I want to play.
Old 06-22-2012, 08:13 PM
  #27
bdo
bdo's Avatar
Originally Posted by bdo' timestamp='1340328117' post='21801805
[quote name='Curtis61' timestamp='1340105492' post='21793281']
[/quote]
Always a good idea anyways, even in cars with WOT cutoff! It's hard on the compressor cycling on and off if you are going WOT a lot, especially since the clutch re-engages at high RPM as soon as you lift. Ask me how I know you can blow a clutch this way...
Old 06-23-2012, 05:00 AM
  #28
I don't mean literally free power as without giving up something for power but recycled power is what I meant, using an electric motor to run the belt which its gonna charge the battery that the motor is using even tho is recycled power I see it as free power since u ain't really giving nothing up to move the motor... Sorry I'm not very good at putting my thoughts on the screen...
Old 06-23-2012, 02:01 PM
  #29
rob-2's Avatar
Originally Posted by JFUSION
Originally Posted by rob-2' timestamp='1340072571' post='21792596
WOT will have the compressor turn off, so I cannot imagine you could measure the difference. I would say ~1% for AC. It's such a small difference there is no MPG improvement free with it on or off.
Having the a/c compressor turn off at WOT is best but a lot of older Hondas didn't do that. I'm not sure if the S2000 did this or not.
How old are we going back? Just about every car I've own starting in the mid-90's has done this.
Head to the track and do some WOT runs with the AC on. You'll see, it gets plenty warm. Heck it's been in the high 90's here and at a few of my on ramps with WOT from 3-6k gets the compression turned off. I have to drive slow to stay cool.
I've also noticed the high RPM cutoff too.
5upa_mari0
06-18-2013 05:00 AM
OUTSTDN
07-17-2008 04:33 PM
chairmnofthboard
18
05-29-2008 07:56 AM
Quick Reply: How much HP does the A/C drain?
