how much coolant does oem radiator hold?
i was looking to replace my engine coolant and i need to know how much the oem radiator holds. i will be using honda type 2 coolant and they sell it by 1 gallon jugs.
get two jugs of Honda coolant if you are draining the system.
Don't forget to properly bleed the system.
I've done mine twice now and 2 jugs has been good both times. Use a funnel and don't overfill as you bleed it with the rad cap open.
