How many miles before you get your valves adjusted?
I think the 1st valve adjustment should be done between 7K and 10K miles (after break-in). The valve clearances have been reported to be poorly adjusted from the factory, and they should change most during break-in, as they seat themselves. If you can do it yourself, that would be much better than having a shop do it. I doubt a shop would put nearly the TLC into the adjustment that they deserve. It is not particularly difficult, but requires a few tools, and a couple hours.
I don't think there is such a thing as a good price, since I don't believe this is a job for someone else. The cheaper the price, the less time and patience they are going to put into it. The gasket won't need replacing.
Originally posted by hyperpm
Honda dealer in my area quoted $150 plus cost of new gasket. Good price?
I also did this myself, because I like to put in a little more time and get the clearances perfect, not "close enough". Perfect on this car is difficult to achieve, but that's how I like to do things.
Originally posted by Nobody
Anyone have a link for instructions?
https://www.s2ki.com/forums/showthread.php?...&threadid=93197
Originally posted by gernby
It isn't hard, but you really do need to have a Helm's manual if you are going to do it yourself.
This will allow you to put your screwdriver through the top of the 10mm socket while you adjust the clearance. Very Cool and they are only $29.99.
