How many bars do you run at on temp
Old 02-23-2009, 03:56 PM
ChefJ's Avatar
4 bars is ok for a short amount of time. At 4 bars your fans should have come on. The thermostat fails open.
Old 02-23-2009, 04:35 PM
negcamber's Avatar
Yeah...4 bars is bad. Check to make sure you don't have a radiator leak.
Old 02-23-2009, 04:52 PM
Former Sponsor
Moddiction's Avatar
Never seen 4 bars yet. Hope to keep it that way.
Old 02-23-2009, 05:01 PM
Slows2k's Avatar
4 bars on a Stock AP1 is overheating.
Old 02-23-2009, 05:02 PM
mikegarrison's Avatar
Originally Posted by Slows2k,Feb 23 2009, 06:01 PM
4 bars on a AP1 is overheating.
...Unless you have the Modifry mod.
Is this a used car? Maybe the OP's car has the Modifry gauge mod installed and he doesn't know it.
Old 02-23-2009, 05:05 PM
Slows2k's Avatar
fixed*
Old 02-23-2009, 05:26 PM
lowandsmooth's Avatar
Well if it does run to 4 bars i can excelerate and it will run down to 3 almost emediatly.
my possibilities
thermostat
weak water pump
clogged heater core
I have no coolant leaks...
Old 02-23-2009, 05:28 PM
That's because you are getting more airflow and thus more cooling.
Is the car used? You really might have the Modifry mod. IIRC, you can pop off the kick panel over the ECU and take a look. I think that's where it gets installed. It's been so long since I did mine that I don't remember for sure, though.
http://www.modifry.com/products/ect/ap1.htm
Old 02-23-2009, 05:37 PM
Ill look I doubt it the reason being it just started it has ran at 3 bars for some time.
Old 02-24-2009, 12:25 AM
ahrmike's Avatar
^oook. If it just started somethings wrong. check it.
Make sure you have enough rad fluid to start...then see if you can burp the system
also, are your fans kciking on? when you say 'when I acc it goes away" it sounds like your fans arent kciking on, so when you get more airflow (moving) the temp goes down.
by the way, stop driving it too...aluminum block + overheating = easy way to warp your head.
Quick Reply: How many bars do you run at on temp
