How low is to low to impact handling?
#21
I don't think my JICs are that great, but I'm pretty certain I'm not bottoming them out. The ride height has no effect on damper travel at all (same as the Buddy Clubs). If the Tien flex is designed similarly to the JIC or BCs, I expect that they wouldn't have a bottoming problem either. Optimal suspension geometry, spring and damping rates would be my concern.
#22
Administrator
gernby, put a zip tie around the piston of a rear shock go drive really hard, especailly at an auto-x or track day and see how close it gets to the hat. I bet you'll be supprised. There is a reason we have remote resivours on the stock rear shocks.
and suspension adjustment has nothing to do with bottoming out or limiting travel.
#23
#26
#28
Originally Posted by StinkyTofu,Dec 8 2004, 02:03 PM
Thats really interesting, i think i'm gonna try that on my tein RA's. I'm still confused though when you say suspension adjustments can't change the amount of piston travel. Don't the flex's and bc's have adjustments so that you can still lower it without changing the amount of piston travel?
#30
Originally Posted by gernby,Dec 8 2004, 01:36 PM
Do the Koni Yellows have external reservoirs?
Also, do you think cutting the stock bumpstops would give the shock more travel?
I left mine alone, but i'm second guessing myself. I'm using the Koni yellows with KG/mm's on the lower perch.
