How to install a hardtop with pics...
#151
The wires are located behind the panel that is behind the driver seat. Unplug the wires that connect to the softop window and connect to the adopter wires that came with your oem hardtop.
#153
Thanks for this installation guide! The installation of the hardtop and the brackets is surprisingly easy! It only took about an hour and a half for me to pull the panels and install the top. Then about an hour to install the panels again and adjust the top (if necessary.) I can't see anyone needing to go to the dealer for this install. Save your money, do it yourself, it's easy! You really can't mess anything up.
#154
As far as bending the metal bracket for installing the side catchers, is that absolutely necessary. I just completed the install on a Mugen-style top (using OEM hardware) and I managed to bolt them in as is on both sides. Any thoughts on this?
#155
When installing the catchers, (oem softtop still in) I can get all 4 bolts in on the drivers side but only can get 2 on the passenger side. The holes dont align anymore(i bent the metal while they were still in)
Any trick?
Any trick?
#156
Your problem may be using the shorter bolts that came with the car. I used these short bolts installing my HT several years ago. The passenger side wasn't a problem but the drivers side I could only get three inplace. Two bolts may/ should work well enough and worth a try. Easy enough to go back with longer bolts if you should notice any problems.
#158
#159
The red circled ones are the bolts I could not get in.
The thread are soooo far off center behind those holes its almost impossible to even start to thread it in.
Doesnt make sense if the other two are in I dont think.
Is there a way to raise that black piece at all by prying somewhere? When I took out the last bolt before trying to install the catcher I felt that whole piece shift as I took it out
#160
