How hard is it to install DEFI BF gauges?
Old 02-09-2006, 01:25 PM
C45P312's Avatar
Default How hard is it to install DEFI BF gauges?
Thanks guys. Pics or even a write would help. Did a search and came up with no write up but with pictures of installs from like 2003.
-Carlo
Old 02-09-2006, 01:46 PM
Erick S's Avatar
Subscribing...
Erick
Old 02-11-2006, 09:05 PM
C45P312's Avatar
Old 02-11-2006, 11:10 PM
kane.s2k's Avatar
It's really really simple. It's only 4 wires to actually wire. Light source, 12v+ ignition, 12v+ power, ground.
Under the dash is a fuse box that has places that you can connect some male connects into (no shielding). If you look, you'll probably see it. It has a light 12v+, 12v+ignition, 12v+ always on, and then just connect the ground.
I'll try and search around for a picture of what I'm talking about.
The sensors are just regular sensors you put on. They are just like any other gauges. The whole process is really simple.
You daisy chain the gauges together. (You will see a total of 3 connectors on the back of the gauge. One of them has 2 together and another all the way on the top). You connect one wire to the pair, then one out to the next gauge.
controller--> gauge1--> gauge2--> gauge3....etc
Old 02-11-2006, 11:13 PM
kane.s2k's Avatar
https://www.s2ki.com/forums/index.php?showt...l=gauge++sender
https://www.s2ki.com/forums/index.php?showtopic=99530
Old 02-12-2006, 09:09 PM
FF2Skip's Avatar
Carlo, why do you need exhaust gas temps?
Old 02-12-2006, 10:14 PM
DJFriar's Avatar
I'm looking at adding some of those as well, what gauges would be the best to add?
Also, where's a good place to get the A-Pillar Gauge Pods?
Old 02-13-2006, 09:16 AM
C45P312's Avatar
Because DEFI doesnt make A/F gauges in BF Imperials.
DJFriar: I would look at Science of Speed for thier a-pillar pod
Old 02-13-2006, 09:22 AM
C45P312's Avatar
Thanks bro.
Old 02-13-2006, 09:23 AM
FF2Skip's Avatar
So EGT is a good estimate of A/F ratios?
Quick Reply: How hard is it to install DEFI BF gauges?
