How get to the stock ECU?
Old 07-02-2009, 09:59 PM
STAIN's Avatar
Default How get to the stock ECU?
Hi,
Want too get too the stock ECU, wondering where its located and is there any threads on how to get to it?
thanks.
Old 07-02-2009, 10:10 PM
camuman's Avatar
drivers side kick panel. its not really hard. just pop a few panels and boom there it is.
Old 07-02-2009, 10:46 PM
STAIN's Avatar
[QUOTE=camuman,Jul 3 2009, 04:10 PM] drivers side kick panel.
Old 07-02-2009, 11:13 PM
AusS2000's Avatar
Then it's the passenger side. LOL
Seriously, pull the sill cover, then pop off the kick panel. It's held in with one (I think) 10mm bolt.
Old 07-02-2009, 11:17 PM
STAIN's Avatar
Thanks Aus, are you running a after market ECU or piggyback?
Where did you put the aftermarket ECU?
Old 07-02-2009, 11:20 PM
AusS2000's Avatar
Aftermarket. AEM EMS. It's installed under the passenger seat.
Old 07-02-2009, 11:38 PM
STAIN's Avatar
How do you get the black clips off that hold the center carpet in place?
Old 07-02-2009, 11:47 PM
AusS2000's Avatar
Not sure what clips you are referring to. Under the sill panel the carpet is hooked onto a body seam. I simply lifted it up and ran the cable along there. Then I made a slip in the carpet where the seat bolts to the floor and pulled the cable out there.
Old 07-02-2009, 11:55 PM
STAIN's Avatar
Ok, Ive removed the carpet and up to a silver sheet lining I need to pull this off?
Or is it better to make a cut where the ECU is only if knew where it was located then I could cut it there...
Old 07-03-2009, 12:06 AM
AusS2000's Avatar
Hmmm, don't remember any silver lining.
Quick Reply: How get to the stock ECU?
