How to get a few more miles out of your tires.
Old 06-11-2003, 06:46 AM
  #21
xviper's Avatar
[QUOTE]Originally posted by genghiskwong
[B]so the consensus is now to flip?
What about the arguments regarding value and handling?
with value - I could see how doing this prolongs the life of the tires (esp those with greater amounts of camber), but does it offset the price for remounting and balancing?
Old 06-11-2003, 07:15 AM
  #22
xviper's Avatar
[QUOTE]Originally posted by gernby
[B]Increasing tire pressure can cause some tires to wear out quicker.
Old 06-11-2003, 07:32 AM
  #23
PJK3's Avatar
hrm... i think i'm going to give the flip a try... the insides of my rears are showing some wear...
so... around 34 -36 psig for rears... what is a good pressure for the fronts? i'm guessing the same, but i'd like to verify to make sure. i just put a new set of S02's on the front and hope to keep them for a while... and i probably have about 9k on my rears and outside of some inner wear, they seem to be doing well... (i don't autox and no burnouts, etc.)
I don't flip, but so far my wear seems to be reasnably even. I run 36 psi on the fronts and 34-35 psi on the rears....gives the steering a bit of eagerness.
Mac - what do you mean by 'eagerness?'
Old 06-11-2003, 08:03 AM
  #24
xviper's Avatar
I've been running the same pressures on the front OEM's (35-36). So far, they look real good.
Old 06-11-2003, 08:09 AM
  #25
PJK3's Avatar
[QUOTE]Originally posted by xviper
[B]I've been running the same pressures on the front OEM's (35-36).
Old 06-11-2003, 08:11 AM
  #26
Former Sponsor
Gernby's Avatar
Pro Care, an auto maintenance chain, only charges $11 per wheel to mount and balance. $20 sounds pretty outrageous.
Old 06-11-2003, 09:30 AM
  #27
StrangeDaze's Avatar
I got a quote from a local Tire Kingdom the other day: $30 per tire. When I immediately became apprehensive about the deal, he quickly said he'd do all 4 tires for $100 and then implied that our tires cost more because stiffer sidewalls take longer to mount. Smelled fishy to me, so I am shopping around.
Old 06-11-2003, 09:43 AM
  #28
Former Sponsor
Gernby's Avatar
Jeesh. The place I am talking about above charged $11 each for R compounds.
Old 06-11-2003, 09:46 AM
  #29
Hehe, thanks. I'll check with some local ProCare's then. Someone also told me to try Discount Tire. They are supposed to be cheap. Plus, all the ones around here allow you to easily watch them work and since you are watching them, they always use a torque wrench on the lugnuts.
Old 06-11-2003, 09:56 AM
  #30
Former Sponsor
Gernby's Avatar
My experience with Discount tire is not very good. Around here, you hear many car guys talking about the "Discount Tire Torquing Technique" in a very bad way. When I asked how much my local Discount Tire would charge to mount and balance R compounds, they told me $150 for 4, since they are difficult to mount without damaging the wheel.
Quick Reply: How to get a few more miles out of your tires.
