How to get a few more miles out of your tires.
Old 06-10-2003, 06:38 AM
afetsman's Avatar
I recommend this with the front tires too, 25k miles and still going.
Old 06-10-2003, 07:48 AM
Sev
Sev's Avatar
I've always done the flip. I also run 3-4 psi more than the recomended pressures. Add stiffness to sidewall and distributes the patch more evenly...
Good post.
Old 06-10-2003, 08:21 AM
MacGyver's Avatar
I don't flip, but so far my wear seems to be reasnably even. I run 36 psi on the fronts and 34-35 psi on the rears....gives the steering a bit of eagerness.
Old 06-10-2003, 08:28 AM
xviper's Avatar
Originally posted by NNY S2k
Did the higher air pressure ( 36 lb. vs. 32 lb. ) effect the handling?
I rarely drive at or close to the car's limit so I can't say for sure. All I can tell you is that it handles just fine for me.
[QUOTE]Originally posted by vjarnot
[B]
Maybe it's just me, but that tire on the right just looks squirrelly.
Old 06-11-2003, 02:10 AM
NNY S2k's Avatar
I'll have to give the added pressure a try. Thanks for the info
Old 06-11-2003, 05:42 AM
genghiskwong's Avatar
so the consensus is now to flip?
What about the arguments regarding value and handling?
with value - I could see how doing this prolongs the life of the tires (esp those with greater amounts of camber), but does it offset the price for remounting and balancing? Xviper paid $40 CDN, what is the price in the US?
with handling - I have always heard that when you flip tires that have camber induced wear, the is an increased likelyhood that the tires will be squirrly. The geometry of the contact patch further reduces amount of available surface contact. On a tight turn in which the normal tire would "roll" slightly onto the outer tread, you would find yourself with an nearly bald tread. I can see how this would work for average daily driving in civic mode, but anything more would seem dangerous.
Are these the cases, or am I just
for the PSI: definitely do it. better gas mileage and longer wear.
Old 06-11-2003, 05:54 AM
Former Sponsor
Gernby's Avatar
Increasing tire pressure can cause some tires to wear out quicker. The rear OEM S-02s may do fine above 32 PSI, but my Kumho 712's wore out pretty fast in the CENTER of the tire at 32 PSI. I actually corded my driver side rear tire right in the middle. I am running 30 PSI in the rear now.
Old 06-11-2003, 06:07 AM
gernby,
what psi do you run your 712s all around?
30 in the rear, what in the front, and how agressive do you drive?
Old 06-11-2003, 06:19 AM
Former Sponsor
Gernby's Avatar
Originally posted by genghiskwong
gernby,
I am actually still running S-02s on the front (at 32 PSI). I keep coming getting "hand me down" used ones from local S2000 owners. I drive pretty aggressively, which wears out my rears in less than 5K miles. I get some awesome drifts going with S-02s on the front, and 712s on the rear.
Old 06-11-2003, 06:24 AM
Former Sponsor
Gernby's Avatar
I agree that high tire pressures will increase fuel economy and responsiveness, but there are trade offs. If air pressure is a little too high, the tire will wear more in the middle, and if it is too low, the tire will wear more on the outside. Increasing pressure will also reduce the normal operating temperature of the tire and reduce the contact patch, which will reduce total grip.
Quick Reply: How to get a few more miles out of your tires.
