How to fix clutch buzz
Hey guys I just wanted to shed some light on the horid clutch buzz we get a lot. I had my clutch replaced about a year ago with an ACT clutch and ACT throw out bearing. When it was installed, properly or botched the day I picked it up, it had the buzz. So my friend is going to school and is in the automotive field and at his school they have lab where they work on cars with instructors to learn what they need to do in real life situations. I had asked him if he could take my S up there and take apart the clutch and see if he could figure out what was the problem. Once he had taken it apart the ACT throw out bearing was either installed incorecty or warped or made with a flaw I ordered an oem honda throw out bearing and the sound is gone no more clutch buzz and since I had it done through my friend and for school it was $100 for the part and thats it! Hope this helps my fellow S2KI memebers, Tops always down
I know when I had gotten the clutch buzz I looked for days trying to find a way to fix it and I was unlucky searching on this forum for a fix. So if you can't stand the buzzing anymore you could have your mech replace the throwout bearing it would prob run you around 600 for the part and install $500-600 seems normal for a side job for this.
Thanks Craig
Sorry if there is other topics about this I know when I searched I was unable to find one.
Thanks Craig
A TO bearing will not cure what is known as clutch buzz here on s2ki.
You may have had a noise, but it wasnt "clutch buzz".
Clutch decel buzz is ALWAYS caused by a non-precise disc, allowing the disc to clamp down in a non-centered position. The TO bearing is not in the equation at this point.
ACT disc is famous for it. Stock disc will cure it.
Hey Billman, I think I have the same problem, but its a new car (to me) and there was no documentation on the clutch. Where should I start? I do however, have a nice warranty that covers my drive train (after a small deductible). Is it almost better to just take it to Honda and have them fix it?
