How do you shift the rear subframe?
I didn't want to hi-jack the Rear Camber Maxed Out thread but I read something mentioned about shifting the rear subframe. How is this done exactly and can I do it or will I need an alignment shop to do it?
your going to need to take it to an alignment shop because you wont know how much you are shifting when you shift the sub-frame you will have an effect on both sides. say your camber is -1.3 on the right side and your -.9 on the left if you move the sub-frame to the the left you will increase camber on the right and decrease camber on the left that way you can match them. if you want I work in Waldorf MD I could do an alignment at my work. and if you had a specific way you want to align your car I could do that as well as long as the adjustment is there.
