How do you make your own Oil catch can
Is there a diy to create your own catch can. I remember somebody went to home depot and purchased a couple things for 12 dollars which looked good to create a catch can.
Does anyone know what parts are needed for this or how to accomplish this.
Thanks
Thanks
inline compressor filter(for air compressor)
nipple for inlet and out let
taflon tape
auto grade fuel line(dont use none reinforce rubber hose, it will be flat and melty in a month)
taflon tape
Just do a search for oil catch can. This is what I made. Make sure you use the fuel line hose (black). The clear hose will collapse under high heat. It actually works. I get about a small tiny teaspoon of oil every two tanks of gas.
Originally Posted by rikhemi,Jun 15 2007, 04:58 AM
Is it ok if i use synthetic. Ive been reading in other post that the filter element in those air compressor cant handle synthetic oil under high pressure
Originally Posted by JawKnee,Jun 15 2007, 08:34 AM
Could you provide the post(s) with this observation?
i am using syn blend for a year and nothing bad happen yet, worst case i have a broken filter housing, that thing only cost 10 buck so i am not too concern.
the filtering size is around 5 mircon, that's better than all the big name tuner catch can
Originally Posted by iam7head,Jun 15 2007, 12:18 PM
there's a orange sticker on the compressor filter housing
Originally Posted by JawKnee,Jun 15 2007, 12:23 PM
Hmm... I don't recall seeing a sticker. I'll have to go look. I've been using synthetic oil with mine as well.
like i said mine been using syn blend for a year(actually one year and two months) and they are fine
IIRC it's likely referring to the plastic bowl as being vulnerable to the oil.
BTW - it's not under any pressure. It's under vacuum and its not very much of a load compared to the pressure it would see in compressor usage.
honda9krpm
06-06-2004 11:16 PM
