Member S2000 Classifieds and For Sale
how do i remove stuck oil pan! please help
S2000 Technical and Mechanical discussions.
06-04-2011, 12:23 PM
robertjr314
how can i remove my stuck oil pan.
i need ideas.. i have all bolts
removed, its just stuck with honda bond.
Like
robertjr314
Find More Posts by robertjr314
06-04-2011, 04:01 PM
rastus
You can lever it off carefully with a medium sized blade screwdriver. Just be sure not to scratch the joining surfaces.
Like
rastus
Find More Posts by rastus
06-04-2011, 04:24 PM
meccjoo
you can use a pry bar, but if you can wrap it with a cloth or something so it doesnt scratch.
Like
meccjoo
Find More Posts by meccjoo
06-04-2011, 07:14 PM
sillyronny
It's not stuck. Pry harder... I had the same issue.
Like
sillyronny
Find More Posts by sillyronny
06-04-2011, 07:24 PM
jh4db536
Knock it loose with a rubber mallet?
Sent from my T-Mobile G2 using Tapatalk
Like
jh4db536
Find More Posts by jh4db536
06-04-2011, 08:23 PM
aresk3b
Easy with pry bars!!!!
I would try hitting it with a rubber mallet in different directions to break the honda bond.
Like
aresk3b
Find More Posts by aresk3b
06-05-2011, 08:48 AM
SgtB
Are you sure you have every bolt? I missed the two in the middle while in a hurry.
Like
Who’s Here in Wee Hours VII
8.4k
232.7k
A couple valves turning white
15
518
Paint Protective Film
Front bumper alignment issue
Nys inspetions
24
840
SgtB
Find More Posts by SgtB
06-09-2011, 04:39 PM
robertjr314
okay, i got it guys.. thx for the help.. I forgot the two transmission bolts.. after that she came right off.. thanks
Like
robertjr314
oil pan removal...
AndyFloyd
11:52 AM
oil pan stuck
shift9k
01:22 PM
oil pan
outlawzs2k
09:23 PM
How do I get that last bolt out for the oil pan
JDM S2000
06:09 AM
HELP! Removing oil pan
VTECturbo04
03:04 AM
Back to Subforum
View Next Unread
HID Bulb Help!
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
02:37 AM
