How do i remove Hard Top Inner Panel?
I want to remove this inner panel on my hard top but i don't see any screws. Do i just pry it off? Will I break any snaps if i do?
there are clips holding it. best if you have a long trim tool to reach and pry by the clips. BE SURE if you do this you dont pry on the outer skin of the hardtop to prevent dents. best is to wiggle and pull until the first clip comes undone and then you can see the other ones. start at bottom back edge, from memory there is 1 clip along glass edge directly in the center of the panel or sure.
Not sure if you are talking about the plastic side panel or the headliner ?.
The plastic side panel just pops off, it is just held in place with basic Honda plastic clips much like the other panels of the interior.
The headliner slides in and out of the clips that are glued to the metal hardtop, you don't pop it off, but more like slide it in and out of position.
