How do I know which to get?
Is there something I need to measure? Or would either a 60/70mm both bolt up? I have the OEM currently on and was just wondering. My cat is sounding like it has rocks in it and I figured instead of a OEM replacement, I'll opt for a test pipe and spend the remainder that I would of on a slight tune.
So is there an issue with going bigger?
Always get the size that matches the exhaust pipe to keep a smoother flow. ..at least that's what I gather from reading Gernbys thread on his exhaust. Although you probably wont see anything positive or negative unless its dynoed
Yes, 70mm would be the desired choice if you're running anything other than a stock exhaust (70mm is 2-3/4"), and the 60mm would be the choice if you're running a stock exhaust.
Saad_Z
12-16-2013 05:52 AM
