How do I install new spark donuts in vc?
I thought the old ones came out so hard due to high mileage but it looks like it's just a really tight fit. I just finished valve adjustment and have the gasket set for the valve cover. The VC gasket was leaking very bad anyway.
I just want to get it back together and go to bed
i know wat the donuts are.. its the round ones that go around the 4 spark plug tubes.. but what was the question? are u having a leaking issue? if so.. did u put some hondabond on the half moon areas?
The longer you leave them in, the harder they are to remove. I swap mine every 30K in all of my hondas. I use a small screw driver to pry them out. Be careful not to scratch the sealing surface. I pulled some out of a honda at 100+K and it was much harder.
Hi
thanks for the info.
I took the old ones out and wanted to know if there were any specific ways people recommended to pop the new ones in. I was surprised by how tight a fit the new ones were...
I wound up just pressing down really hard on opposite edges with the top of a hammer. I didn't know if there were any better ways out there.
Thanks
Thanks
