How do I install my DiGrappa Brace???
Just received my DiGrappa brace and figured out where it should go underneath. Pulled out a couple of the existing bolts and quickly found they are much too short to use with the DiGrappa, and the bolt heads don't fit into the brace bolt channels. This is not a difficult installation, to bolt on a brace, but I am stuck. Can anyone with this brace give me a clue?
You should have got longer allen head bolts with your new brace. Check your box and see if the new bolts are in there someplace. Torque the new bolts to 28 ft lbs. At least that's the factory spec. I went a little higher.
I have now installed four of these units on various cars. Jack up the car and get the lay of the land. See where the 4 bolts are located. Then do the install with the car on the ground and level. Use a small jack to hold the X-Brace in place. This is the easiest way to do it as all the holes will line up! As stated you should have received a set of longer bolts with the kit.
Utah
Utah
[QUOTE]Originally posted by Utah S2K
[B]I have now installed four of these units on various cars. Jack up the car and get the lay of the land. See where the 4 bolts are located. Then do the install with the car on the ground and level. Use a small jack to hold the X-Brace in place. This is the easiest way to do it as all the holes will line up! As stated you should have received a set of longer bolts with the kit.
my bolts were wrapped in a stirofoam packag, easily mistaken for package material. Easy install after you get all 4 bolts going. Rick or Mark should be able to tell you the size, so that you could go buy them if you didn't want to wait. They could express overnight the bolts to you in a small package for less than 10.00. Good luck!
Originally posted by bash
Please do. An X-Brace is one of the few mods I was thinking of purchasing but not if the improvement is only marginal.
make sure that you reuse the seemingly useless OEM bracket-like pieces that should go between the car and the X brace -- otherwise the X brace will rub the oil pan
