How do I clear the headlight corners for my AP1?
I know it has been around but I can't find out how I can clear the orange on my s2000. Is there two different look to it? I saw some with the four lines still attached and some that are completely white. By the way if I do it is it something that would attract cops and I could get a fix it ticket for? Please help I just want to make my s2000 more aggressive and the orange isn't doing it.
In order to do it you must remove your headlights, bake them in the over and then separate the lens from the housing. Then you can pull out the diffuser (the orange thing)
You have a few options for replacement, you can modify your orange ones like myself and a few other members have done. Link
You can order some JDM clear or smoked from Ricks
Link
Now, the difference about the bars being connected or being smooth is the USDM and JDM differences. The USDM clear has the bumps just like the orange ones that come stock, that is the USDM style. These clears are no longer being made and are getting harder and harder to find.
The ones that are smooth and do not the bars are the JDM clears or smoked as linked above.
As long as you replace the bulbs with an orange bulb so that the light still illuminates an orange color, you will be legal, however check your local laws if you are truly concerned.
Good luck.
-Mike
Link
Good luck.
-Mike
You can by bulbs that look like chrome but burn in the DOT amber color
If you are local I can help you do the clear out, I'm in Florida 34601
If not there should be someone that can help you do it in your local
JDM CLear
USDM Clear
JDM
JDM CLear
USDM Clear
JDM
https://www.s2ki.com/forums/index.php?showt...0&#entry1501337
Look at this. It gives you a step by step on how to do it.
This is the real one you want, covers the entire process from start to finish.
http://www.ricks2k.com/info/instructions/diffuser.pdf
-Mike
gregsju29
Member S2000 Classifieds and For Sale
07-31-2008 06:33 AM
