how dangerous is it to work on the car on jack stn
[QUOTE=Slows2k,Apr 21 2010, 01:09 PM]A 4 post lift is no safer than jackstands. They are supporting the car from the same points. If the car falls from 6 feet or 2 feet you are still
It is always good practice to throw something (wheels/tires) under the rockers when working on a car on jackstands or a floor jack.
You don't do it because the car is LIKELY to become unstable and somehow slip and fall on ya, you do it because it just MIGHT.
I've seen plenty of cars on jackstands where one is cocked and supported only on two of four feet due to the car moving around when the other end was lifted.
Cars can and do manage to fall from jackstands and floorjacks and injure and even kill people.
Not a bad idea to throw something under the rockers...
ok I think I wlil do that just for some extra safety.....I think more unsafe is the actually process of getting the car up onto the jack stands. Perhaps someone would be willing to put together a how to thread. I've tried a couple of methods so far. I think whats best for future is to get some 2x4's to put under all four wheels drive up on them and then I can jack it up easier.
To get the car down, I lift up the rear center, and remove all rear stands. I then jack up front center and remove the front stands, I place a jack under the driver side front lift point, and lower the front center jack so the car is then resting on one jack located under the driver side lift point. Pull out the jack from the front center point, lower the jack on the driver side and pull out the remaining jack once the car is on the ground.
Very simple to do, and no need to drive on any objects to get the car higher.
yeah like everyone said just throw the tire under there just as a precaution, a mechanic died around here like that, he was just using the jack, the poor guy was working on his gfs car trying to finish the car for valentines day.
Received 1,377 Likes
I have no idea what your neighbor is talking about. Maybe he just wanted to chat up your wife?
Always push the car hard back and forth before climbing under it. My dads friend and track buddy died at the track when he went to help someone work on their car that they jacked up, it fell and crushed him.
