How to bypass CEL after installing a test pipe
Old 07-02-2007, 12:29 PM
afrsyl's Avatar
Default How to bypass CEL after installing a test pipe
Hey guys,
I bought a test pipe and I'm ready to install it but I've heard that the CEL light comes on afterwards.
Is there a way to resolve the CEL issue?
Thanks!
Old 07-02-2007, 01:12 PM
mxt_77's Avatar
I suggest searching and reading the FAQs. It's been covered (many times).
Old 11-17-2007, 03:44 PM
mxt_77's Avatar
Good job reviving a 6-month old thread (that should've never existed to begin with).
Old 11-17-2007, 05:31 PM
stevoe88's Avatar
Old 11-18-2007, 03:18 PM
millertown15's Avatar
IBTL
Old 11-18-2007, 05:02 PM
HMFIC's Avatar
umm...just a quick question.... I have that spark plug none fouler and its EXACLY the same one in the pic. Do i still need to drill out a bigger hole with a 1/2 inch? or does the O2 sensor fit right in and just screw it up to the second fouler then into the test pipe?
Old 11-18-2007, 05:49 PM
mxt_77's Avatar
F'n A, man... it took me literally 27 seconds to find this thread:
Mechanical O2 Simulator installation stuff
About 6 posts down in that thread are explicit steps for the procedure.
Old 11-18-2007, 06:15 PM
ionlylive's Avatar
Is anybody running the 70mm new Invidia TP with CEL fix and still having it throw a light???...If so what's everyone using to trick it, just the anti-foulers...i heard the Blox from A-J's is pretty good
Old 11-18-2007, 08:12 PM
stevoe88's Avatar
If you put another anti-fouler on top of the cel fix, the o2 sensor will be too far out and it wont fit. I bought the 2007 o2 fix from e-autosports and it still throws a CEL after 50 miles or so. The only option for 2007's are, a) try stuffing steel wool into the o2 fix b) Go with a hi-flow cat c) wait for hondata or something to have a program to turn the o2 sensor off.
Old 11-21-2007, 06:41 AM
HMFIC's Avatar
do i have to reset the ECU after this? does it reset itself?
Besides disconnecting the battery, how else can this be resetted?
Quick Reply: How to bypass CEL after installing a test pipe
