How big of a deal is AP1 oil consumption?
Old 12-16-2009, 02:39 PM
Skatethesea's Avatar
Im running the VTSC a and a catch can looped from the PCV to Intake manifold. I only consume a Qt. or less every 2.5k miles. It is an 2001 AP1 with appx. 75k on the motor. So the problem really isnt that bad.
Old 12-16-2009, 05:46 PM
jimi's Avatar
Originally Posted by 11Past9,Dec 16 2009, 07:17 PM
I'm being told that burning oil is going to eventually (sooner than later) make the engine go boom...
I want to be able to buy one of these, keep it a while and enjoy it. Not take a performance hit because each time I drive it hard it kills it more...
That is my concern, my mind was made up about this car and now it just feels to me like I'd be buying a lost cause.
Get the car don't talk ur self out of it. the S is not a problem car. It's a race car, they consume oil. It's not like burning oil were it gets into the combustion chamber. If this is the case find another S. Good luck
Old 12-16-2009, 06:27 PM
s2klariat's Avatar
Just do it man. 2001 Ap1 about 75,000 miles on it as a DD and I rarely see any oil consumption. Just stay away from Mobil 1 and you'll be fine!
Old 12-16-2009, 07:26 PM
11Past9's Avatar
So they don't BURN oil, they CONSUME oil?
What's the difference? I'm a little novice...
Old 12-16-2009, 07:50 PM
dsthez's Avatar
it only burns when you drive hard cuz it revs so high its not a big deal at all, you wont be thinking about that with the top down at wot
Old 12-16-2009, 10:00 PM
viper_driver's Avatar
mine has 120K, uses no oil. I put 5 quarts in at the oil change every 3K and never need to add any more.
Old 12-17-2009, 04:21 AM
11Past9's Avatar
So...
When looking at one I am considering to buy what do I want to see for compression numbers and other things to know it's going to be a good one that won't give me problems?
Old 12-17-2009, 05:05 AM
ZDan's Avatar
You want EVEN compression numbers, within 10psi. Don't go by absolute numbers as they will vary depending on the equipment used as well as other factors.
Old 12-17-2009, 05:10 AM
11Past9's Avatar
So if the compression of all the cylinders is within 10psi of each other what does that say overall about the car and what I should expect for say the next 50,000 miles?
Also what are ideal compression numbers, I would think if they were lower that means the car is down on power too?
Old 12-17-2009, 05:39 AM
Conedodger's Avatar
I have autocrossed my AP1 at 15+ events per year for 6 seasons. I use Mobil 1 and only need to add 1/2 to 1 quart over 6k miles.
Quick Reply: How big of a deal is AP1 oil consumption?
