How to adjust a carbon trunk?
It's not really under the hood, its more like in the trunk
I removed 1 of the 2 springs. It's better now, but it still is pushing the lid up..
It sticking a bit out, on the side were the spring is pushing.. Some say to lay something heavy on it over night, or heat it up and placing something on it...
The passenger side is fine as you can see in the photo..
Its the driverside that is sticking out.
Originally Posted by JsAP1,Dec 10 2004, 12:10 PM
... Every CF trunk I have seen needs to have the springs removed or it will look off or look like its not made right. Thats just how they are...
it was not pushed out at all, i had it installed with springs too.
it's not an easy fix.
in fact you can't "fix" it-
it's how the trunks are made, and you have to find the right one.
i went through 3 cf trunks to find the decent fitting one.
Originally Posted by JsAP1,Dec 10 2004, 10:10 AM
I had a CF trunk and you do have to remove both springs.
Originally Posted by seung,Dec 10 2004, 09:22 AM
i had seibon cf trunk for a while,
Originally Posted by xviper,Dec 10 2004, 09:36 AM
So, you're saying that a CF trunk lid is so flexible that the spring tension causes it to bow? If this is the case, it doesn't sound to me like it's a very good mod to do.
with the 2 springs on it was like a launcher! It popped open like crazy!
It was on both sides up. now only the driverside. I'll remove the spring tomorrow, I'm at work now...
Remember dont slam the trunk either once the springs are out. Just drop it about 5 cm away.
Originally Posted by JsAP1,Dec 10 2004, 12:40 PM
... You went through 3 when infact your first one should have been just fine. Its all about adjustment and experience with these things...
PEOPLE, TAKE THE SPRINGS OFF BEFORE YOU SLAP ON YOUR NEW CF TRUNKS!
but i would like to point out one thing.
my first trunk, i took springs outta my car even before i touched it.
it came out like 1/2 incjes both sided.
it was custom made, and it was made wrong to begin with.
(i won't tell who made it, but a lot of s2ki.com people already know who it is.)
second one, did the same, then later i put the springs on just to see what happens.
it was fine. no flex, no bow, no pop-ups.
third one, i just threw it on with out taking the springs out.
it was fine.
perfect fit, no popping out, no flexes.
so i dunno.
may be it's the trunk, maybe it's the springs.
we'll see what Pharrel will say after he takes the springs out.
