how accurate is the stock guage cluster?
Old 05-12-2004, 09:27 PM
MacGyver's Avatar
Most quality "analog" guages these days days are nothing but digital circuits driving needles attached to stepper motors. I would trust an LCD element to be quicker to light than a mechanical motor/needle combo to overcome inertia and get to the right spot....measurable difference, but not by speed of human senses alone. Since it's all digital at some point along the chain, they're only as good as the signals being fed to them (essentially digital pulses themselves pulled from a notched gear/tooth).
Old 05-12-2004, 09:51 PM
kane.s2k's Avatar
[QUOTE]Originally posted by MacGyver
Old 05-13-2004, 12:10 AM
T S2K H's Avatar
its accurate enough
Old 05-13-2004, 06:00 AM
MacGyver's Avatar
Originally posted by kane.s2k
Aren't the signals for the speedo, temp, etc all analog and then at the very end converted to digital for the LCD. So for the issue on accuracy, it'd basically be dependant on how much resistance on the whole analog portion of the circuit.
Not sure about temp, but do you really need 0.01 degree resolution? Anything within 5 degrees is more than adequate.
For the speedo/tach, the signal is essentially digital in nature. You're getting a square wave back with a changing pulse width, or PWM
Resistance is not necessarily an issue to circuit accuracy, it will depend on circuit design.
Old 05-13-2004, 07:10 PM
SimbaDogg's Avatar
Old 05-14-2004, 10:26 AM
LordMagnet's Avatar
Originally posted by mikecl713
rpms are off by a hundred
Tach is off by a hundred (looks more like 200 to me). Checked from my VAFC (reads actual revs).
Old 05-14-2004, 03:38 PM
kane.s2k's Avatar
[QUOTE]Originally posted by SimbaDogg
Old 05-14-2004, 05:40 PM
SimbaDogg's Avatar
[QUOTE]Originally posted by kane.s2k
Old 05-14-2004, 05:53 PM
kane.s2k's Avatar
I've also seen digital clusters in ralley cars in WRC. Not sure if all of them do, but most. Just argueing against your post about most racing teams using analog clusters.
Spoon uses the stack cluster which is basically more of a fad thing now as the sensor displays and such it has are pretty useless with all the other devices available.
Old 05-14-2004, 06:17 PM
SimbaDogg's Avatar
ok...the arguement has yet to move me....so far, thats wrc, f1, and cart. there's a lot more racing organizations out there than that.
Quick Reply: how accurate is the stock guage cluster?
