Hot Start Issue, please help, need to smog soon and need to know what to fix
Old 09-28-2012, 08:48 AM
baZurk's Avatar
The FPR is on the fuel rail which is located above the intake manifold close to the valve cover. Look in that area and you will find it.
Old 09-28-2012, 09:00 AM
zbt1985's Avatar
Originally Posted by jordanksartell
This is the FPR. Pull off the small diameter vent line from the top. NOT the larger diameter fuel feed line from the bottom.
If it's not the FPR what do you think it might be?
Old 09-28-2012, 09:17 AM
baZurk's Avatar
I think it's worth just checking the FPR. Based on the description of the symptoms you gave i would say that it is a 90% chance the diaprhagm is bad.
Old 09-28-2012, 09:34 AM
MM3Kwolik's Avatar
Yep....especially since you stated you have to give it gas to get it running...
Old 09-28-2012, 09:40 AM
zbt1985's Avatar
I found the part, can I check it by just putting as rag undreneath the hose, to see if gas is being poured out? Or is this a 2 man job?
Old 09-28-2012, 09:48 AM
MM3Kwolik's Avatar
Dude....I already told you... pull off the small 1/8" vent line....start the car (or at least try to) if gas is squirting out of the top of the FPR, it's bad.... one person, you can put a rag there if you'd like to catch any gas that does come out if it is bad....but cranking it once or twice will tell you whether it's good or bad.
Old 09-28-2012, 09:49 AM
zbt1985's Avatar
I understood all that, and I really do appreciate the help!
I was just wondering if I could try and do this on my own, or needed a friend to come by to watch the hose is all...
Old 09-28-2012, 10:01 AM
HarryD's Avatar
Try it yourself, just see if the gas squirted out or not.
When you put your keys in and twist, but before you press start, can you hear the fuel pump engage/prime? Like a little bzzzzt?
Old 09-28-2012, 10:02 AM
zbt1985's Avatar
I'm pretty sure I can, but will double check when I go out for lunch in about an hour or so...
Old 09-28-2012, 12:46 PM
zbt1985's Avatar
I do hear that buzzt.
Quick Reply: Hot Start Issue, please help, need to smog soon and need to know what to fix
