Hose replacement question
Hi,
I have a crack in one of my hoses on my 2008 s2k.. See the attached picture with the gloved hand pointing to the crack in the hose.
What do I need to purchase to replace this hose? Is there a generic hose I can buy or do I need a specific Honda part?
What size do I need? Do you have a link to the hose I should get?
Thanks,
Matt
Thanks,
Matt
generic vacuum hose will work just fine. that just goes from intake to pcv valve. if you want the oem part i'm sure i have a spare in my parts bin
yeah I just keep rolls of various size hose around for that stuff. Needs to be able to handle oil exposure but it is common stuff that you just cut to length. I think I bought the last stuff I have from McMaster Carr.
Part number = 17131-PCX-000 It's like $20 shipped.
Received 1,418 Likes
IIRC, its 8mm (5/16") ID. Or maybe 3/8 (10mm)? I can't remember. It can be measured.
You need PCV hose. You can find it on bellmetric.com or parts stores. Or just buy from Honda
windhund116 (02-28-2024)
Part #: 95005-75003-10M
Bulk hose, vacuum (7.3 x 3000)
This worked for me.
If purchased in bulk from Honda. You get a coil of about 3 meters. Cut a piece off to match length of the old PCV valve hose, approximately 230mm.
Outer diameter of the hose measures about 13mm. Inner diameter from part description appears to be 7.3mm and measures about that, if a bit less with calipers. Label on hose itself reads “Y-TEC-TA>CSM. ECO < 200123” if you want to try to source without Honda premium.
Note, markings differ from the original hose which read something like “TA - ^^ - 0207”.
The bulk hose is a bit grayish, vs. more blackish on the original, not sure if due to age.
This worked for me.
mposner305 (03-04-2024)
