Horsepower=Torque
Originally posted by schwett
not sure if that's lag or inability of the stock low-rpm lobes to move enough air... i've rarely seen a turbo spool so suddenly!
on the other hand, that torque curve is GORGEOUS from 6k -> 9k!!!!!!! 300 lb-ft and flat as a board.
The torque is actually pretty low compare to the amount of power I'm making. Stock bore and stroke just can't make no more unless I play with aggressive timing.
Originally posted by Switzerland1010
So no matter what the 5252 equality seems to remain the same.
yes. it has to. per elistan's equation above, horsepower is simply a multiple of torque and engine speed divided by 5252. so at 5252 they are equal. all dynos actually measure torque and speed, then they do the math.
Originally posted by evo s2000
That's correct, but just remember, the scale for both Horse power and Torque has to be the same. Some people get confused about it.
Now, if you're talking about the scale on a dyno chart, then yes they need to be the same if you want the torque and horsepower curves to cross at 5252, but even if the scale isn't the same it doesn't change the fact that at that RPM torque and HP are the same numbers even if the curves don't cross at that point because of a difference in scale.
