Horrible MIS but good compression.
Originally Posted by turbo_slug,May 7 2010, 03:45 PM
have you ever peeked into your injector ports? when i had misfire problems, everything was fixed when i replaced the injectors + cleaned the injector ports. the injector ports were full of gunked up carbon (looked like wet espresso grounds).
i wonder what are the chances that your cleaner somehow washed away enough crap from your intake manifold that the car ran better for a short while. anyway, try cleaning the fuel injector ports to see if that helps. if you don't want to replace the injectors, try soaking them in kerrosene over night?
btw, since it sounds like you have an obd2 scanner, what's your long term fuel trim number?
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Also maybe try to clean your IAC valve which can cause these symptoms (although not under load). Maybe map whack (or replace Map sensor) too. I had similar problems with mine and turned out to be improperly gapped plugs (the gaps had widened over time). I also suggest checking out your TPS. HTH
Problem fixed! ended up being one of the coil packs was "lazy" still firing, but not strong! i appreciate everyone that threw out ideas and tried helping a fellow s2k owner diagnose an issue!
Originally Posted by jdmb16crx,May 8 2010, 06:59 PM
Problem fixed! ended up being one of the coil packs was "lazy" still firing, but not strong! i appreciate everyone that threw out ideas and tried helping a fellow s2k owner diagnose an issue! ![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
My coil packs arrived today; will try them out tonight. Wish me luck...
So far, the new coil packs seem to be doing the trick.
No misfires during their first 3 or 4 short trips (total of ~15 miles and 30 min, with no ECM resets and several minutes idling).
Side note - as expected, I ordered P/N 30520-PNA-007 but received P/N 30520-RRA-007.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
NFRs2kevin
02-26-2010 03:24 PM
