Horrible gas mileage
Old 05-08-2008 | 08:23 PM
qbmurderer13's Avatar
Default Horrible gas mileage
Hey guys, lately ive been finding my cars gas mileage is getting worse and worse, im putting about $20 a day. My drive to and from work is about half hour but its mostly highway so it shouldnt be too bad regardless. I havent been vtecing or anything. Ill fill the tank next time and see exactly how many miles im getting but my gas gauge just plumits... Is there anything I can do to help or is there a common problem in s2k's that will hinder gas mileage..?
Old 05-08-2008 | 08:31 PM
snakeeater's Avatar
Fuel leak or poor tune running way rich.
Old 05-08-2008 | 08:43 PM
Actually with the tune we leaned it out, it was running super rich. And we also only tuned for wide open throttle. I also dont notice any leaks.
Old 05-08-2008 | 09:02 PM
vtec4life's Avatar
Check the fuel lines, or injector seals, also do you smell any gas and two it could be a faulty guage, i konw some people on here have had problems. Just some ideas.
Old 05-08-2008 | 09:04 PM
shotgunjimmy's Avatar
only thing i can add is that the gauge in mine seems a bit off. goes back and forth alot. sitting right around/just below half with about 150 miles on this tank.
Old 05-08-2008 | 09:09 PM
SNKS2K's Avatar
how far do you get on a full tank?
Old 05-08-2008 | 09:29 PM
Havent checked, like I said in my original post ill fill up my tank tomorrow and start counting the miles. Just wanted to see if there could be a common problem that would cause bad gas mileage.
Old 05-09-2008 | 02:23 PM
ans2k's Avatar
i get an average of about 290 miles if i run it to the empty light, i drive both city and highway, is that about right?
Old 05-09-2008 | 02:39 PM
craig2teg's Avatar
That sounds about right. I avg. around 280-290. Sometimes a bit more if I drive like a grandma .
Old 05-09-2008 | 03:25 PM
jyeung528's Avatar
you gotta fill up and count the miles, then fill up and divide by the gallons for re-fillup.
you can't base it on how much you spend per day.
you guys at 280-290 are phenomenal...i get an average of 220-240
