Horn, cruise control, 12V power socket not working
#21
Originally Posted by Gloffer,Mar 31 2005, 09:41 AM
Did replacing the fuse fix your problems?
#24
Some of these symptoms sound like my problem. Check to make sure all 3 brake lights are working as well. If they are not, but the horn still works, it's probably the brake pedal switch.
Greg
Greg
#27
Originally Posted by AusS2000,Jun 15 2005, 06:03 AM
What do you guys mean by 'cable reel'? Is it a set of cables that runs from one place to another that you buy as a part?
Anyone got a picture or diagram?
"The cable reel allows all the horn, SRS (airbag), and cruise wires to be spun around with the steering wheel and not get tangled. The importance of not turning the steering wheel lies in if the cable reel moves (and you're not sure where center is), it has to be recentered. It's designed to turn with the wheel and will only turn 2+ times until it locks up. You'll need to turn it until it locks, turn it back (until it's straight up), then turn it again (away from the lock) one more time."
