Hondata heat shield gasket
Old 04-02-2002, 04:07 AM
  #21
marcucci's Avatar
I don't believe bleeding will be possible. The spacer blocks the hole where coolant flows out of the block and into the manifold (i.e. under pressure). Blocking it will prevent flow into the manifold and hence the bleed screw. The other bleed "nipple" is still be in the coolant path (pressure), but it's also a different path.
I have the hole blocked and have no problems. I bled the system the way I usually bleed cars, by running the system open and letting it cycle multiple times. I keep checking and adding coolant over a period of days. It will eventually bleed itself this way. Not ideal, but I've never had luck with bleed screws on coolant systems.
Old 04-02-2002, 06:24 AM
  #22
KYS2000's Avatar
Waiting for mine to come in now...
Old 06-14-2005, 11:22 PM
  #23
TougeBomber's Avatar
I've heard many good things about this espacially for long use like mountain driving or Auto-X...
I still have waranty and was wondering if this is a product that would affect my waranty in any way?
Thank You
Philip
Matty_Vr6
02-05-2013 05:14 PM
1.8TsBLOW
11-08-2006 04:47 PM
FIdreaming
08-16-2006 09:29 AM
shotime
05-10-2004 08:14 PM
swtazn97
04-21-2003 10:43 PM
Quick Reply: Hondata heat shield gasket
