Hondata Gasket
#22
what do you mean by some freezing?... freezing of what?... car is typically kept outside in the winter and seldomly inside. I like to take it out and about when there is no snow and as little salt on the road as possible.
#23
You know the manifold runs in a vacuum right? Well moisture that comes in with the intake air can freeze in low temperature/pressure situations so, you could possibly get some feezeing on the throttle body or IAC. There's a reason they have heaters built into the IAC and throttle body. Once the engine gets good and warm, they aren't really needed any more. You can drill through the blockage on the hondata and still have the heaters if you want.
