Hondata?
you could go with the greddy e-manage ultimate. From what I have readm it is a decent system. I am currently doing research into it so I am not expert, but you might ask around about that one and people will help you out. Take it easy.
-Ian
-Ian
or a VAFC 2. Like the greddy, it is a piggy back ecu controller. The E-Manage changes outgoing signals from the ecu and the VAFC changes incoming signals to the ecu. Both are pretty good units. If you need to change your timing, definately get the E-Manage then. I've got a AFC Neo which is about the same as the VAFC 2 with more bling factor, but use it as a display too which the E-Manage can't do. Best thing is AEM EMS, but that would be overkill unless you're forced induction.
