Honda Tech Told Me Passenger Rear Tire Wears First
Old 01-09-2010, 10:57 PM
  #21
mister x's Avatar
Originally Posted by SpitfireS,Jan 9 2010, 01:41 AM
You can swap directional tires L/R too, but you have to take them off the wheel.
IMO its best to keep worn-in tires spinning in the same direction.
I completely agree, however the OP needs to do some figuring to make sure it makes economic sense. Given the cost to dismount, remount and balance a tire; it may not be worth extending the tread life as opposed to simply replacing the tire.
By running a little more aggressive camber you may be able to reduce shoulder wear due to cornering.
Old 01-10-2010, 12:13 AM
  #22
Saki GT's Avatar
Originally Posted by Elistan,Jan 9 2010, 06:29 PM
My open-diff truck will do as you say - too much gas and the inside rear tire spins up all day long.
However my S2000, under certain situations, certainly does behave like your single axle example. During 90-degree right turns, like entering a street, I can hear the inside tire "hopping" as it over-rotates for the distance it's traveling. It's a much different result from the open-diff behavior you describe. IIRC, it's the same reason our cars pull to the side when given gas and one of the rear tires is low on pressure - the LSD acts much like a single axle when under load. (Well, 50% like one, isn't it?)
This is what I've attributed to my passenger tires wearing faster. All those tight, 90 degree turns when you're on the throttle and the diff is locked = spinning the right rear, thus, faster wear.
Old 01-10-2010, 01:13 AM
  #23
starchland's Avatar
just ask the people that drive on the other side of the road...
but does it have anything to do with the direction the driveshaft spins?
Old 01-10-2010, 02:37 AM
  #24
SpitfireS's Avatar
Elistan Posted on Jan 10 2010, 12:29 AM
The Torsen works because of rev difference between L&R.
Turning when both wheels have grip (your example) makes it work hard.
Because:
#1 - rev difference & applied torque generates lock.
(like you say it starts to act like a single axle)
#2 - equal grip in slow corners does not allow lock.
What to do?
Rely on Oil.
The diff oil has to allow the gears inside the Torsen to turn at different speeds while those different speeds press the gears together to generate lock.
Torsen claims the unit can run on ATF, but in the S2000 IMO it shouldn't.
The ring & pinion need the GL-5 and so does the Torsen.
I've noticed odd behaviour in slow tight corners myself.
The car acted like it just didn't want to turn in, like understeer, especially under light throttle, or as much throttle as taking the turn could handle.
This behaviour started suddenly, almost overnight.
At that time I had an unknown diff oil, put in by a dealer.
When I bought the car I had engine/trans and diff oil changed by that dealer.
It had been in there for a while but certainly not longer then the official diff OCI.
(I guess you allready see where this is going)
I went to another Honda dealer, one that workes on S2000 regularly, and asked them to check the steering rack as I figured that must have been it (it wasn't)
They put in the SAE 90 GL-5 diff oil, the Honda Marine stuff.
They kept a sample of the oil that came out of the diff, it looked pitch black and was pretty thin compared to the fresh SAE 90.
Probem solved.
Instantly.
In the first corner I allready noticed the change.
Back to normal.
What diff oil are you using?
When was it changed?
IMO, the diff should not lock when both wheels have equal grip.
The oil should deal with it.
When I manuever around on the small parking lot in front of my garage box I sometimes here the bricks move, I guess that is what you describe.
Bricks are slippery, have sand in between them, grass growing, etc. IOW don't have that much grip.
On tarmac I've never heared or noticed it.
NFRAP1
02-06-2006 07:41 AM
converted
08-08-2005 05:07 PM
03_AP1
07-14-2005 08:23 AM
KeithD
01-18-2003 04:19 AM
DeeGYM
01-07-2003 08:15 AM
Quick Reply: Honda Tech Told Me Passenger Rear Tire Wears First
