honda ripping me off!
Dealer, nearly $2k, and lies about effort involved, vs $100 at an independent shop.
Lesson learned?
Sent from my SM-G920P using IB AutoGroup
Lesson learned?
Haha yeah the dealer thinks the S2000 is the equivalent of a Lamborghini. I got quoted $112 for an oil change. They gave me the same excuse for the price ..."because its an S2000" .I laughed in their face and walked out.
Dealers have overheads to pay and that is why they charge more than everyone else.
Toyota dealer wants to charge me $159 to replace just the key fob battery for my Prius..Lol talking about ripping off, the dawn key fob battery only cost 3 bucks the most..
You can always do the job yourself, for ~$300 you can buy all the tools you'll ever need to do your own oil changes. A good floor jack $150, 4 decent 3 ton jack stands $80, $30 for some wheel chucks, and the rest on a set of ramps to drive up, and put your floor jack on the jacking point, and a cheap ass filter wrench, and a 7 quart pan.
Plus you can use those tools for other things, like transmission fluid, and diff fluid, or basically anything else short of removing the engine(need a cherry picker/engine hoist for that). Add in a hydraulic press, and a decent multi-meter and you can basically dismantle, diagnose, and repair anything on this car yourself.
Definitely never going back to the dealer with my S. I just figured why not let them see what they tell me my independent shop that did my motor swap only charged me $600 for labor i could just image what the dealer would of told me.
You don't need to remove the subframe to replace any bolt or cam thats involved with alignment, stripped, seized, or anything else. A sawzall and a lot of cursing maybe, but the subframe can remain in place.
Received 1,713 Likes
For fast oil change without getting under the car you can do this too. With a Fumoto valve it is easy to drain the exact amount of oil you want to adjust for an overfill. I can change the oil without jacking the car or getting underneath it save for the oil catch pan. Oil change with just the hood open.
Some say a rock (unlikely) can hit it and may cause a leak but as I do not off road in the S I will have much, much bigger problems if something hits the valve. Had it for 4 years now; here it is on my S:
To make reading (both sides) of the dipstick easier with clean oil, sandblast or finely sand the stick end.
In addition to the comments above, to make reading (both sides) of the dipstick easier with clean oil, sandblast or finely sand the stick end.
