Honda Hypoid Gear Oil (differential)
#21
Originally Posted by revhi,Jan 7 2005, 01:26 PM
Abuse is abuse, if you launch enough times its goin to take its toll on the parts. He also had a reinforced diff.
#22
Originally Posted by topcat7111,Jan 7 2005, 06:56 AM
I have over 10k miles with the 75w/90 M1. And so far i have no problems with my differential.
#23
Originally Posted by topcat7111,Jan 7 2005, 03:11 PM
Or do some stupid shit like towing your boat with your S2k, no lubricant in the world is going to save your inferior design differential unit.
#24
straight 90 isn't good for people who do *not* live in ideal climates. 75w90 protects better when the diff. is cold. some the straight 90w fluids i've seen pour like molasses. imagine what happens when you're driving in sub-freezing temperatures.
#25
#26
2) LE-607 has a pour point of -11 degF, much lower than any other 90w known to me. I considered cold weather issues when I did my analysis and recommendation, lo these many months ago. I would not recommend it for use in severely cold climates, but unless we are talking Arctic here, I would not agree that Mobil1 provides more protection at lower temps - LE-607 adheres to metal tenaciously, and creates a coating which protects even in boundary lubrication situations. The benefit of a multi-vis is more around fuel economy in a differential. This is quite different than in an engine, where oil flow to the top of the engine and the rapid establishment of oil pressure, are critical.
3) Honda has stuck by its 90w advice, and has no secondary recommendation as do other mfrs for cold climates. Yes, there have been some TSB's saying this or that multi-vis is OK, but that may be more for dealer convenience or Canadian use. Until they change the recommendation in the owner's manual, I would be wary of dismissing the need for a 90w unless ambient conditions demand it. The load carrying capacity of LE-607 is way beyond what M1 or any other multi-vis can do.
4) My car is in a garage which never goes below 55 degF, so the whole issue of cold weather is moot for me.
5) I am not saying that 75 or 80w90's are BAD - in fact, I have 5 gallons of LE 9921 in my garage right now. But for the S2000 and MY use, I am not skimping on the vis.
6) Yes, the S2000 has the Miata gear set. But are standard Miata gear sets shot-peened? Miata's ads for its turbo'd car make a deal now about shot peening, so this may again be an apples and oranges thing in saying the gear sets are identical. I don't know for sure wither way.
7) My understanding of the principle of operation of the Torsen diff is that it exerts tremendous force on the carrier, and that the strengthening of the 2004's was done to reduce diff failures unrelated to ring and pinion failure. That of course, is not a lubricant issue at all.
Hope this helps.
RR.
#27
Originally Posted by gernby,Jan 7 2005, 12:34 PM
My understanding is that the ring and pinion are the only common parts with the miatas in the diff. If you guys don't think the problem is lubrication related, why are you chaning your diff oil so often? The owner's manual recommends a 30K mile change interval.
mykeh
08-01-2014 03:49 PM
Road Rage
04-27-2004 04:56 PM
