HKS Hi-Power exhaust gaskets.
Comrades,
I've searched and had no luck finding out exactly what sizing I need to buy and where I can get them.Also Scott from Ballistic mentioned that one of the gaskets is a weird Honda one so it has slightly different bolt pattern and that I need one of those as well.
Can you guys please confirm and point me in the right direction?
Many Thanks,
Dmitriy
Many Thanks,
Dmitriy
I have the HKS Hi Power as well. Due to one of the gaskets at the back can leaking, i decided to take them off completely for cleaning. Once off I measured the diameter of the pipe and measured it at 2 inches. I haven’t sourced gaskets yet as i only took them off at the weekend, but i plan on bringing the exhaust to the main exhaust shop and seeing what gaskets they have. Then refit with new stainless steel bolts.
Unless you are you referring to the gasket at the CAT?
Yeah that special gasket between the exhaust and the cat/test pipe. I need to know where I can get that one. (Honda?)
Also need every other gasket for the exhaust and the bolts too.
s2k90230
19
10-22-2005 02:40 PM
