highest compression ratio
I was just curious if anyone knew at what is the highest compression ratio an F20 can run on pump gas (91/93) without having to pull timing?
Not that I'm planning to raise the compression anytime soon, but just out of curiousity I'd like to know.
Im running 12.0:1 on 93 octane with no problems. The thing that you need to look at is Timing Advance. You can run 13.0:1 on 93 octane but your timing with not be as high. I run 12.0:1 wiseco pistons and Inline Pro is using 13.0:1 compression. Once Im done tuning I would love to compare the timing maps.
JSR_AP2
18
09-03-2013 11:50 AM
