High speed vibration
I have another question...if my car will rattle at 120km/h, what might be the possible ways to cause that rattle?I currently running A032 on my car and kg/mm springs....thanx in advance
Warning,
If you recently have had your tires changed I would STRONGLY suggest that you check to see if the fronts are on the front of the car andthe rears on the rears........the last tireshop that did this for me swiched 2 wheels and I lost 3 out of the 5 lug nuts on each wheel. Switched wheels will result in play in the front of the car. So check it out.
Bobby
Bobby
wheel balancing could be an issue, but it would be shakey before you even hit the brakes. still could play a factor. but it looks to me like you are braking hard and its getting overheated.
