High Revs on Cold Start
Old 11-27-2007, 08:20 AM
clawhammer's Avatar
Originally Posted by paoverload,Nov 27 2007, 10:58 AM
40 degrees or so - nothing exceptional.
I'm most worried about these sort of revs before the oil pressure is established and oli properly circulated i.e. wear. None of my other fuel injected engines have ever reved above say 1250 rpm on start - that's meant to be one of the advantages of processor control - you can control these things.
How is idling the engine at 3000 rpms any different then gently driving the car and cruising at 3000 rpms?
It's not a problem, I wouldn't worry about it.
Old 11-27-2007, 08:36 AM
RACER's Avatar
Try resetting the ECU
Run 5w-30, or 0w-30 in the winter.
Old 11-28-2007, 09:39 AM
Vik2000's Avatar
mine's at 2k when cold
Old 11-28-2007, 10:12 AM
RACER's Avatar
Mine jumps to around 2,200 initially at cold startup, then quickly decends toward idle.
Old 11-29-2007, 10:17 PM
veilside_s2k's Avatar
mines around 2000-2500 on cold start in morning.. i was worried till i saw this post. it drops down once its at normal temp or im driving it
Old 11-30-2007, 12:00 AM
agent's Avatar
coldest it's been so far was -8 celsius. I started the car, revs were at 2500rpm for a couple of seconds and then dropped to 2k as usual
Old 11-30-2007, 12:04 AM
Apex_AP1's Avatar
I've had that same issue for a while now, u are fine.
Old 11-30-2007, 06:57 AM
Vik2000's Avatar
hm... but his is in excess of 3k revs lol
Old 11-30-2007, 07:05 AM
MikeyCB's Avatar
Meh, so reset the computer and see what it does!
Um has he tried that yet in the past 3 days? It takes minutes to do...
Old 11-30-2007, 08:00 AM
Vanishing Point's Avatar
Mine idles at 2000 rpm when cold initially then falls to normal idle.
Quick Reply: High Revs on Cold Start
