High oil consumption
Originally Posted by INDYMAC,Oct 9 2006, 03:34 AM
Why don't you try Valvoline Maxlife or Maxlife synthetic next time. It has additives that expand seals that may help your situation.
Yes, I have used it and liked it very much. Here are some reviews from the "oil journals" in the UTH forum:
http://forums.s2ki.com/forums/index.php?showtopic=198014
Here is a UOA:
Here is a UOA:
I burn a qt every 1k miles to 1600 miles. I don't know what is up with this engine?? Sometimes it will go 400 miles with out burning a drop of oil...Sometimes it will burn 1X or 2x on the dipstick just going to work and back...less than 70 miles of travel. I noticed when i used Mobil 1 it will burn more once the oil gets old..Right now i'm using Redline and it's still has high oil consumption!! I don't see any smoke from the tail pipe on any of the cold start. Once in the blue moon, i'll see some black smoke when i'm going fast on a tight sweeping right turn from my rear view mirror. But again i'm running a test pipe so it's normal for it to smoke a little from time to time. Anyway it has 39k miles and it's still running mightly strong...
Originally Posted by iamhomin,Oct 9 2006, 02:24 PM
I'll give it a try, but isn't it recommended for engines that has 75,000+miles? How about the regular convention motor oil from Valvoline?
Originally Posted by Kenpo_S2000,Oct 9 2006, 04:28 AM
Anyone actually try the valvoline maxlife that can post a review?
I beat the living sh-t out of the car everytime i drive her, maxlife is synblend, i never use the full syn. version.
the car still pulls great compression and leakdown test result is well within the spec.
RR gave a rave review on the maxlife line, i personally been using it for couple of years on my 89 legend. I was first introduced to it by my shop instructor(who is a complete crazy car nut)
you could get alot of oil in the PVC, a catch can might be a good investment, I have a Homedepot unit and it's full every 3-4 oil change
Originally Posted by iamhomin,Oct 8 2006, 12:17 PM
First time hearing of Krankvents. Any threads?
https://www.s2ki.com/forums/index.php?showtopic=424678
