High compression kit and AEM EMS
Hi
Researching for my next year project I ws thinking in Getting the toda High Compression kit, or similar, and the Toda Cams.
Their kit (pistons+rings) increase compresion to 11.7. They told that and AEM EMS or similar is mandatory becuase of the increased compresion.
I think that AEM EMS is not mandatory, becuase in japan the S2000 runs same compression with the sotck ECU. And we run here in Europe the same fuel than Japan, @$6 per gallon ,
I also asked if the kit can be used with the toda Cams spec A and they told me YES. Spec B cams can be used Too but needs the adjustable cams pulleys that does not comes preset, which is a pain for me here in Spain since the S2000 is very very rare here.
I'm sure you can get a set of higher C:R pistons than that!?! something like 13:1 maybe not from Toda but I'm sure I've seen them.
I have a spare JDM ecu if you want it mate
JDM ECU could help but what about the inmobilezer?
tell where I cna get higher compressoin, if is UK better for me
Juan
You can have pistons made to any spec you wish as long as you send you're existing piston off to the company unless they already hold a spec for the S2000, say JE or ROSS for instance.
regarding the immobilizer I have a CAT 1 alarm and immobilizer fitted extra anyway so its never bothered me, plus AEM doesn't have that option anyway
Andy
Andy
I shouldn't think you would you should be able to swap any ECU over as our key doesn't have a transponder in it like other cars where the ECU immobilizer relys on the key to arm/dissarm it.
Juan
Originally Posted by turbo_pwr,Aug 25 2004, 10:17 PM
Juan I was always told only North American S2000s have the immobilizer feature.
this is the first time.
How is going your setting?
Juan
