Hide-N-Seek Coolant leak
Originally Posted by BBV S2K' timestamp='1355849546' post='22217514
just go to autozone a buy few feet of that same size of hose and make it yourself
A factory hose from Honda will be tight and fit properly.
with the proper hose the Honda spring clamps are very reliable, I also think they are much easier to use then worm gear clamps and more friendly to the hose as well.
Either way the more impotent issue to your repair is the post repair bleed of the system to remove trapped air. If you have an AP1 I can provide detailed info. If it's an AP2 you will have to search.....
Utah
P.S. As the coolant system will be "open" plan on doing a Coolant change
just by sayin I went there to get some drive-shaft bolts... they wanted to charge me shipping.. AND THEY HAD THEM IN STOCK... lol
before that I went to get a thermostat and same thing... they had it in stock but wanted to charge shipping... 15+ for shipping and handling
