HID went out.. HELP!
About a week ago, I noticed my passenger's side HID would go out and It would have to turn the lights on and off to fix it. I would stay on for no more than 5-10 minutes and go back out. Well, two days ago, I turned it on and it was a dark purple color and then went completely out. The headlight will not even turn on now. I'm not sure if it's a ballast or bulb. I'm going to switch the bulb to the other side and see if it works.. Any input will be greatly appreciated!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Originally Posted by amelite,Nov 30 2009, 10:05 AM
Do you guys know of any place to get a cheaper bulb than the dealership?
buy this kit, cheaper than the bulbs and will brighten up you're night drive.
https://www.s2ki.com/forums/index.ph...=667636&st=100
i ordered two of them at amazon.com.$51.00 ea and free shipping.the oem bulb is a phillips d2s bulb.i replaced it with a sylvana d2s and i like it just fine..you should replace both.make shore you have a #25 tamper proof bit to take the cover off the housing.
