HID not functionning wiring problem? S2K 2005
Hello, I have a problem with my right HID + top orange light. They are not working anymore, both of them, I disconnected the HID connector and tested with key to ON position but no power detected (using a multimeter).
I exchanged relay from left HID and same result, left is OK but right is not.
A strange phenomenon is, when I remove my left (for testing only left HID is fine) fuse the left HID try to lit and shutdown, it seems there is maybe something... I don't have S2000 2004+ hiring diagram..
Any idea what to test to get back HID and top small organge light?
Thanks for your help,
Alex Poulin
La Prairie
Alex Poulin
La Prairie
Originally Posted by S2Kage,Apr 20 2009, 07:02 AM
Uhh... I have no idea what your trying to say, especially in the third paragraph.
thanks
Alex...
so are you saying you have a short and keep blowing fuses? Im confused with what you said you have tried to do? ... test the ballasts and the bulbs, use a test light to make sure you are getting power to them if they do work. Make sure you connected the correct wires... lol you dont need a diagram, just check which ones get power as you turn the lights on and such. Uhh if you can elaborate more on what you tried to do I can help you but like I said, I am confused with what you are saying.
huh. I am confused too.
My HID was funky too, when I first bought the car. turned out a relay was blown, and it was doing something screwy with the ca.r check the relays + shorts and good luck? electrical gremlins suck.
s2cho
09-26-2013 05:52 AM
